06 Pacifica window fog
Old Dec 11, 2011 | 10:21 PM
TrenchRT's Avatar
Default 06 Pacifica window fog
I purchased a Pacifica this summer and now that is has got colder and I have to start using the heat I get a lot of window fogging, just wanted to know if others are experiencing the same thing?
Old Dec 13, 2011 | 11:55 AM
desperado's Avatar
the external air entry door is probably stuck in the closed position. Unplug the battery terminal for 10 minutes, then reconnect. It will reset the system.
Old Dec 14, 2011 | 06:03 PM
TrenchRT's Avatar
Thanks Desperado, I will give it a try.
Old Dec 22, 2011 | 08:32 AM
TrenchRT's Avatar
I tried disconnecting the power from the battery for 10 minutes and still am getting fog. It is from not bringing in outside air.
How do I access the flap that closes off outside air? Is it solinoid or motor driven?
Thanks in advance.
salvonrico@verizon.net
Apr 24, 2015 12:22 AM
spankey
Jun 10, 2007 01:29 PM
f6lover
Feb 25, 2007 10:55 PM
motman
Nov 14, 2006 06:15 PM
dsudak
May 3, 2006 12:29 AM
