07 Pacifica transmission problem
Old Jul 16, 2019 | 02:14 PM
Caliber16's Avatar
Default 07 Pacifica transmission problem
Hello, I have a 2007 Pacifica 4.0 limited. And I keep having the same issue over and over again. It will not come out of limp mode and will not shift out of first gear. I took it to get the computer replaced on it and it worked fine for a about a month then it went into limp mode again. Took it back to the transmission shop and they said I need a rebuild. When I picked it up it was out of limp mode again and drove fine again for about another month then it locked into limp mode again. I don't think it the transmission itself. And I can't seem to figure out what the cause is. I don't have any other issues with this vehicle beside the limp mode.
Old Jul 20, 2019 | 11:11 PM
That Jeep Guy's Avatar
Getting the codes with an OBDII scanner is going to be your best place to start, as it will give you a place to begin focusing on.
I believe there are 80-ish transmission codes(P07xx).
My 07 Pacifica Base 4.0 recently went into limp mode and produced a P0755(shift solenoid B malfunction) code.
I replaced the solenoid pack and so far it has cured the issue.
If your transmission is freshly rebuilt, I would think the problem is something like a bad wire, a bad ground, or a sloppy connector pin/socket.
Again, the codes should lead you in the right direction.
8nracing
Sep 12, 2018 04:24 AM
Arclark2
May 2, 2018 01:45 PM
amen.ak
Jul 24, 2016 01:44 PM
miniowner92
Apr 7, 2015 05:37 AM
sws4420
Apr 19, 2009 10:06 PM
