2004 Chrysler Pacifica no heat
Old May 5, 2018 | 10:37 PM
one hot and one cold tube is a clogged heater core as for the ac issue could be the blend air door or motor
Old May 6, 2018 | 06:39 PM
Kevin Matney's Avatar
I even tried a new used control panel too with no luck. But when I put it in I can hear the doors moving. I think there is heat how but no AC. How do I check the blend door
Old May 6, 2018 | 06:42 PM
I read some were there is way to reset the control panel. Like hold the power botton and the recycle air button
Old May 7, 2018 | 10:09 PM
1. Turn Ignition switch to ON
2) Press both the POWER and RECIRCULATE buttons at the SAME time and HOLD for at least 5 seconds.
3) The POWER and RECIRCULATION lights will flash
4) Calibration should take about about 2 minutes to complete if you have heater control and about 20-seconds if you have Automatic Temp Control system.
5) If lights continue to flash AFTER 3 minutes (manual system) or 20-seconds (Auto system), the control unit has detected a failure. You need a scan tool to pull the trouble codes (Thanks Chrysler). If there’s a trouble code stored, the lights will CONTINUE to flash until the unit completes a successful calibration OR until the vehicle has driven 8 miles.
Old May 8, 2018 | 08:39 PM
  #15
Will give this a try and Thanks.
Old Jul 1, 2018 | 06:05 PM
  #16
goo123d's Avatar
Default Check thermostat.
Originally Posted by u1701
2004 Chrysler pacifica with no heat. I have checked the antifreeze and it is fine. Blower works but just blows cold air. I see two hoses going into the dash from the engine compartment and they are warm, not hot, but just warm. I also noticed when I press the recirculate button it just flashes three times and goes off. any guidance would be appreciated
Check the thermostat. It sounds broken like it is always open. The recirculate button is off if it is in defrost mode
Old Jul 6, 2018 | 08:39 PM
  #17
a broken or open thermostat has nothing to do with cold or hot air inside the car.
Old Jul 7, 2018 | 10:52 AM
  #18
goo123d's Avatar
Default Broken thermostat
so a constant open thermostat will cool the coolant to less than operating 194 F about 150’s I’m guessing an so the coolant entering the heater core is warm, not hot, so air coming out of is Luke warm as described in the original post.
Old Jul 13, 2018 | 11:58 PM
  #19
You can tell with your hand the difference in 150F and 194F heat? Not likely
Plus a broken thermostat would cause the check engine light to come on and give you a coolant temp rationality performance code.
jbro38
13
Jan 24, 2013 05:25 PM
jalo215
Dec 15, 2012 05:31 PM
pmad
Sep 25, 2011 12:32 PM
athenablee
Nov 6, 2009 02:31 PM
user440
Jan 21, 2007 04:58 AM
