2004 pacifica wont start
Old Nov 23, 2016 | 06:50 PM
  #21
rottonj's Avatar
We just got a 2004 Pacifica from our in-laws, it had a random no start issue. Dealer replaced the battery which they were sure it was, wrong! No start the following day. Came across this video and did this fix, we will see if this fixes the issues. The car in the past has also experienced tach jumping around and spur-attic transmission oddities that seem to be associated with the weather. Car has been dealer maintained since new, and has 85k on it in excellent condition , minus the cradle rust which will be addressed shortly. This ground wire is an easy ten minute job and was 7 bucks at Advance Auto. It should probably be first attempt before replacing any parts. Hope this helps myissue and others.
Old Nov 23, 2016 | 06:51 PM
  #22
rottonj's Avatar
We just got a 2004 Pacifica from our in-laws, it had a random no start issue. Dealer replaced the battery which they were sure it was, wrong! No start the following day. Came across this video and did this fix, we will see if this fixes the issues. The car in the past has also experienced tach jumping around and spur-attic transmission oddities that seem to be associated with the weather. Car has been dealer maintained since new, and has 85k on it in excellent condition , minus the cradle rust which will be addressed shortly. This ground wire is an easy ten minute job and was 7 bucks at Advance Auto. It should probably be first attempt before replacing any parts. Hope this helps my issue and others.
Old Nov 23, 2016 | 06:56 PM
  #23
rottonj's Avatar
Woops, doubled up. Cant seem to delete one. Sorry.
Old May 10, 2017 | 09:24 PM
  #24
Mikey0659's Avatar
Having a similar issue you have an 05 Pacifica when you turn the key you can hear the starter turning but the pendix isn't pushing out I put a new starter in and I'll start true 3 times and then do the same thing and I put a new battery in and does the same thing any ideals
wiz kidd
Jun 17, 2014 06:41 PM
bate1
Jan 3, 2012 08:46 AM
chengthao85
Jun 11, 2011 03:08 PM
ekhealy
May 23, 2011 10:47 PM
Kiddi j
Jan 10, 2010 03:59 PM
