2004 using oil
Old Dec 20, 2007 | 06:37 PM
jjstull's Avatar
Default 2004 using oil
I need some help. My wife's '04 has been using oil. It is not leaking or getting into the coolant. It's burning off somehow. Has anyone had this happen and what was the cause? I've read about piston rings in '05 models and valve seals in the head but I haven't heard of anyone fixing this???
I'd like some ammo before it goes to the dealer.
Thanks,
Jason
Old Dec 20, 2007 | 08:02 PM
jamie1's Avatar
Default RE: 2004 using oil
How much is it using? A liter/quart every 5000km/3000miles would be considered normal.
Old Dec 21, 2007 | 07:24 AM
PacificaBus's Avatar
As per Chrysler, some consumption is normal so be prepared to hear that. I can't recall what amount is considered normal. My '05 displayed what I thought was oil consumption but realized that when I changed the oil myself I had to check it twice after running the engine and then had to add some.
Old Jan 7, 2008 | 01:01 PM
jjstull's Avatar
PacificaBus,
You might be right about having to add oiljust after an oil change. I added 1.5 to 2 quarts within 200 miles of the oil change. But since that we have put about 1500 miles on the car and the level is holding better. I'll keep an eye on it especially after the next oil change.
Thanks!
Old Jan 7, 2008 | 03:44 PM
moe's Avatar
moe
You guys are putting 5 and 1/2 qts of oil in every oil change? i have never seen the pac engines burn oil.i work on the every day.great engine.moe
Old Jan 8, 2008 | 08:10 AM
jjstull's Avatar
Moe,
I don't do any work on that car, the dealer changed the oil. I did add a quart after the change but maybe it was low after the change. The oil light hasn't been on since. The dipstick was below the low mark each time the oil light went on.
It's good to hear that don't see many engine problems in the pacifica. It's my wife's car and Ineed it to be reliable.
Thanks,
Jason
Old Jan 9, 2008 | 08:40 PM
jamie1's Avatar
The 3.5L is a very good engine. In my 20 years with Chrysler,I have only seen I major failure with a 3.5L. Main bearing failed on a crankshaft. The early ones[93-97] had weak water pumps,but a total engine redesign fixed that concern. My own 05 Pac with 103,000km uses about 1L every 5000km which is normal.
mwestpacifica
Jul 30, 2013 01:07 AM
Oct 12, 2012 09:26 PM
LT102
Apr 29, 2009 12:40 PM
FULL-THROTTLE
Feb 2, 2009 08:54 AM
mobilespa
Jan 27, 2007 04:36 PM
