2005 Pacifica 3.5 killing me
Old Jul 20, 2020 | 08:48 AM
chargerhp's Avatar
Default Iratic idle
Originally Posted by Mrmurray33
I got every code to go away but the p2074. I have changed the IAC twice. Changed the TPS twice. Have tried to change everything I could think of that was related to the code and nothing is working. I tried to check for leaks and couldn’t find any but I’m not a mechanic but didn’t see any indication of leaks. I just want to pass inspection and nothing is working. Please help if anyone knows anything that may be the cause of this to keep coming back on after I clear it. I’m trying to pass inspection and this it won’t until this is figured out.
My son called the other day with his 04 Pacifica making a noise, throwing codes, idle ruff and transmission shifting into second by itself. When driving after resetting codes the engine would run ruff at a stop light and shift into second gear by itself (limp mode) I had him check the alternator because Pacificas have a decoupling pulley on the alternator that goes bad. We live in different states so I have the tools he doesn't to change the pulley. He went and got a different alternator and all codes are gone, it idles perfect and no transmission shifting problems. These pulleys can ruin everything connected to the belt. The pulley will turn one way freely and lock the other way, if it doesn't replace it.
Chaotix
Apr 22, 2018 06:26 AM
LFOLKJR
Jun 2, 2014 07:10 AM
nick77
Dec 12, 2013 09:33 PM
shannonmci
Sep 16, 2011 06:00 PM
j0z0d34th
Aug 20, 2008 07:24 PM
