2005 Pacifica engine miss
Old May 4, 2011 | 12:15 AM
marko500's Avatar
Default 2005 Pacifica engine miss
I have a 2005 Pacifica AWD 3.5 with an intermittent engine miss in the #4 cylinder with the check engine light on steady. It is worse when holding a steady speed and seems worse when it's cold or damp outside. I have replaced the spark plugs and the coil on the #4 cylinder but it made no difference. Had a scanner put on it and it still shows engine miss in #4 cylinder. Any ideas on what to check next? Thanks for any help.
Old May 4, 2011 | 10:49 AM
fuel injector issue or internal engine issue
Old May 4, 2011 | 11:00 AM
marko500's Avatar
Fuel injector makes sense. As I said it comes and goes and happens mainly at a steady speed, not so much at idle or accelerating. Would a fuel problem still show up as a misfire code on scanner? Thanks
Old May 4, 2011 | 02:31 PM
yes the scanner only reads sensors and relays the info to the pcm then the pcm lets it be shown on the scanner
el camino
May 26, 2015 02:12 PM
Mick
May 31, 2013 05:57 PM
Brad stone
Mar 29, 2012 07:36 PM
SpectorV
Mar 14, 2012 02:06 PM
nick v6
Aug 9, 2010 03:16 AM
