900 mhz transmitter/dvd setup
Old May 27, 2008 | 07:02 PM
mrfixit454's Avatar
Default RE: 900 mhz transmitter/dvd setup
No pix yet.. I ended up finding a harness that is complete from radio to DVD screen/player in my case (VES Megacab).I am waiting for it to be shipped.Its 12 pin on one end (dvd side)and 10 on the other (radio side). Can't you move pins in the connector where you need them? or do you need more wires than are availaible? How about a repair connector for Caravan ot T&C... they use a similar changer.
Do you have a P/N for the lower cable? If so have you searched elsewhere?
Old May 27, 2008 | 07:23 PM
pac2006's Avatar
The pins that I need in the plug have just an open spot where I need a wire. They only installed exactly what was needed and no more. The dealer is tired of hearing from me and they said they have no clue what any of the connectors look like. I have to pull the dvd changer and radio again to take some pics of it. Maybe they use the same style on all their cars. Just different shape plugs. Maybe I could part out a cable for the mega cab to do what I'm trying. The only part numbers I found were on the internet for the same cables that I have. Which would work cause I would take out the pins I need. Its just kinda overpriced. If I can't find anything else that will be my last resort. Thanks.
Old May 27, 2008 | 07:37 PM
pac2006's Avatar
I just found this parts.pdf file for the pacifia. Looks pretty good. http://app4.websitetonight.com/proje...merica.com.pdf
Old May 28, 2008 | 12:32 PM
mrfixit454's Avatar
Good find.. here is from another memeber on a Dodge forum. I would bet that Chrysler uses similat connectors between vehicles. These are for the Dodge RAK radio and VES DVD player.
This is from a MOPAR website that your dealer has access to with out a vin number. It is for repair connectors. This is only for a connector, pins, and about 12 inches of wire. You will have to run you own wire to the radio to make the rest of the connections.
Mopar Package #
05102402AA repair connector
MEDIA SYSTEM-MONITOR/DVD - BLACK 12 WAY
CAV CIRCUIT FUNCTION
1 X510 20DG/LB RIGHT AUDIO AUX
2 X916 20GY/OR SDARS AUDIO RETURN
3 X521 20GY/LB LEFT AUDIO AUX
4 -
5 -
6 A118 18RD/OR FUSED B(+)
7 X511 20GY/LG LEFT AUDIO AUX
8 X910 20GY/DG AUX AUDIO RETURN/COMMON
9 X522 20GY/DB RIGHT AUDIO AUX
10 D55 20WT/OR CAN B BUS (+)
11 D54 20WT CAN B BUS (-)
12 Z957 18BK GROUND
Here is the corresponding connector pin out on the back of the radio.
Mopar Package #
05135638AA -reapair connector
RADIO C2 - GRAY 10 WAY
1 X16 20DG/YL AUDIO SIGNAL RIGHT (+)
2 X917 20DG AUDIO SIGNAL COMMON
3 - -
4 X510 18DG/LB VDO-AUX AUDIO RIGHT
5 X916 20GY/OR SDARS AUDIO RETURN
6 X17 20DG/OR AUDIO SIGNAL LEFT (+)
7 X910 18GY/DG AUX AUDIO RETURN
8 X511 18GY/LG VDO-AUX AUDIO LEFT
9 X521 18GY/LB VDO-AUX AUDIO LEFT 2
10 X522 18GY/DB VDO-AUX AUDIO RIGHT 2
Old May 28, 2008 | 06:09 PM
  #15
pac2006's Avatar
I will run those part numbers by the dealer tomorrow. Thanks. I will let you know if it works.
Old May 28, 2008 | 10:07 PM
  #16
pac2006's Avatar
To me this site looks like repair connectors by mopar for everything. Check it out. http://dto.vftis.com/mopar/main.asp
Old May 28, 2008 | 10:51 PM
  #17
mrfixit454's Avatar
Its having problems loading but is probably a great site
My dealer tried to tell me the repair connectorthat was 12 pins was for a Pacifica.. which it may be but others said it was for the VES player is a durango. Which gets back to my original assumption.. for the radios, screens, DVD's, the 12, 10, 16, 22 pins are probably the same size dimension pins
Old May 28, 2008 | 11:06 PM
  #18
mrfixit454's Avatar
Looks like this is what you need.. do you agree?
[align=center]
Mopar Package #
68020737AA
DVD/CD CHANGER C2 - BLACK 12 WAY
[/align][/align]
[/align][align=center][/align][align=left]This pn 68020737AA does not show up when I search Chryslerpartspeople.com/[/align][align=left]The other side does though.. which I is the part I was originally going to buy[/align][align=left]
Mopar Package # DVD SCREEN - BLACK 12 WAY
5102402AA [/align]
Old May 29, 2008 | 07:26 AM
  #19
pac2006's Avatar
I think it is. I just ordered it through my dealer. $25 is a bit high, but whatever. It looks like you can get any connector you want. I have read so many post about how you can't buy just the connector, and yet there it is. Anyone could easily add aftermarket screens or what they want. Thanks Mrfixit for your input. My project will continue soon.
Old May 29, 2008 | 11:10 AM
  #20
pac2006's Avatar
I sent an email to moparpartsamerica.com and they added the part number to the site. And its cheaper there. Check it out, now you can buy it online. Sweet.
