ABS howl?
Old Sep 19, 2010 | 05:54 PM
RonT's Avatar
Default ABS howl?
2004 Pacifica AWD exhibits an intermittent howling noise under hood after stopping at a stop light after 3-4 seconds with foot on brake and auto in "D", noise then quits after releasing brake. New pads on front & rear. Brake fluid is adequate but appears to be a little dirty. Brake pedal appears to be a little soft. No ABS light comes on. Can this be checked with a code reader? I recently had the EGR valve replaced when the plug popped out. Any ideas or thoughts?
Old Sep 19, 2010 | 08:45 PM
TNtech's Avatar
Noise quits after releasing brake? Sounds like a leak in your brake booster.
Old Sep 20, 2010 | 09:47 AM
RonT's Avatar
My wife informs me that she felt a vibration on the forward floor board thru her bare feet when the noise occurred and then it quit when the howl quit. If there was a leak, why would it not do it all the time? Thanks for your input, I will check that out.
Old Sep 20, 2010 | 07:58 PM
TNtech's Avatar
OK, there was a howl. Now there is a howl and a vibration under the feet. Shew. Now you lost me.
Old Sep 20, 2010 | 08:40 PM
RonT's Avatar
The howl now sounds like a "Foghorn". Dealer mechanic was able to generate the condition and by touching the AC Filter/Drier felt the vibration with the foghorn sound. They have never had this condition before. I left the vehicle with them as the warranty will cover whatever else they find. So far the compressor & clutch are ok. Brakes are ok. What would cause this unit to do that??
Old Sep 21, 2010 | 11:31 AM
TNtech's Avatar
Well, that pedal issue sounds like the ABS pump running. May be some air in the system (as in a leak/pressure bleed off or internal seal) or there is a pump and/or module electrical malfunction.
Old Oct 1, 2010 | 07:14 PM
RonT's Avatar
Default ABS howl? Is now A/C Foghorn sound
Dealer was able to determine that this loud foghorn sound occurs when the high side PSI reached 260psi until the A/C fan turns on and the noise was coming from the Receiver/Drier. They recovered the system and replaced the Receiver/Drier and Thermal Expansion Valve and re-charged the system. Hopefully this will end this saga.
jimmy154
Dec 14, 2019 09:45 PM
bgborden
Mar 7, 2010 09:15 AM
stormz8
Dec 18, 2007 03:31 PM
driabyor
Dec 9, 2006 04:35 AM
Ironside
Feb 24, 2006 10:47 PM
