abs brakes
Old Apr 13, 2006 | 09:54 PM
driabyor's Avatar
Default abs brakes
1994 Grand Cher
My Specs
Drivetrain: 5.2 Auto 249
Axles: stock
Suspension: stock
Tires & Wheels: 255r 70 15 stock wheels
Recovery: 2 - 25' straps, 4 - 3/4 shackles
Armor: none yet
Accessories: 4 lights
User Profile
I have just replaced the master cylinder.
The problem was that the pedal felt like it was bypassing fluid.
I bench bleed the master cylinder first.
then bleed the brakes in the normal way. The book said to hook a code scanner to the jeep and rebleed the system. Which I did.
Then did again the normal way.
HOWEVER the problem still exists the pedal is firm but then bypasses slowly , sometimes the ABS motor comes on . this vibrates the pedal , then locks the brakes. This happens only when the jeep is rolling VERY slow (like not moving slow). AS far as I can tell the brakes are working fine as far as stopping power, both foward and reverse.
The code scanner didnt give any codes.
The abs and brake light both work , BUT are NOT on. And have NOT come on.
1994 Grand Cherokee 5.2 Full time
Old Dec 9, 2006 | 04:35 AM
Default RE: abs brakes
i would say a sensor is giving some bad info making the brakes lock up or a caliper is locking up making the abs think its locked up the wheel
mrbradva
Jun 27, 2013 07:36 PM
Kendegreat
Aug 29, 2010 12:16 PM
DRam
Dec 3, 2009 09:33 PM
ahalas
Apr 23, 2008 11:44 PM
notVERYpleased
Jul 24, 2007 10:19 AM
