ABS Sensors
Old Sep 8, 2014 | 06:35 PM
WDAdams's Avatar
Default ABS Sensors
Is the 1-05166544AC the updated front sensor for the '06 Pacifica. I bought a set for the front and the packages are dated 07/2007 & 08/2007. Want to make sure that this part number is the correct "good" replacement sensor regardless of the date code. Thank you.
Old Sep 8, 2014 | 09:09 PM
call up a dealer parts department give them your vin and they will give u the part number for your car
Old Sep 9, 2014 | 07:18 AM
WDAdams's Avatar
Thank you for the reply. I did give the VIN to the dealer and they verified it to be correct. I did order over the internet. When recieved I noticed the dates codes of 7/2007 & 8/2007 on the packages. Just wanted to make sure that the dates had no bearing on the assembly line vs replacement part. Did not want to install the same defective sensors that came with the car. Guess I did not phrase my question correctly. Thanks.
Old Sep 9, 2014 | 09:56 AM
they will be fine
jimmy154
Dec 14, 2019 09:45 PM
silverdestiny357
Sep 27, 2013 06:19 AM
jezza
Apr 24, 2013 03:30 AM
tCandGrandCaravan
Jun 2, 2011 09:31 AM
KeithC
Aug 12, 2010 09:11 AM
