Adding HID Headlights
Old Dec 13, 2008 | 09:49 AM
broker08's Avatar
Default Adding HID Headlights
Has anyone added factory HID headlights to a Pacifica? Are all the wiring harnesses already there? What parts are required besides the Bulbs and headlamp assemblies? What approximate costs are invlolved? Thanks in advance.
Rick
Old Dec 15, 2008 | 08:05 AM
PacificaBus's Avatar
Default RE: Adding HID Headlights
From what I recall from reading you will need a main module which is very expensive. I believe you can get it to work by adding a harness which connects up to your existing bulb socket. Pretty much it enables you to bypass the module. You will need a specific harness for your current bulb type which I believe is H7. I was able to buy this harness on line and it was very reasonable. Good luck!
Old Dec 30, 2008 | 08:03 PM
awdtootall's Avatar
I installed Pilot HID www.pilothid.com They come with the wiring and ballast as needed when you place your order. Work great.
Otis857
Feb 7, 2011 08:44 PM
jtfrock
May 5, 2010 12:15 AM
ajuillerat
Apr 27, 2009 01:38 PM
sonic gihad
Jan 27, 2009 08:29 AM
May 12, 2006 02:05 PM
