Air Conditioning Filter
Old Mar 27, 2008 | 01:06 PM
farout's Avatar
Default Air Conditioning Filter
In the Owners Manual on the 2007 Pacifica it calls for the Air Conditioning Filter to be changed every 12,000 miles. Thecost at the dealeris $52.[sm=noooo.gif] and at the parts store is $ 32.[sm=signs006.gif][sm=signs006.gif] Can this filter be cleaned by blowning it with an air hose?[sm=goodidea.gif]????
farout[sm=patriot.gif]
Old Mar 27, 2008 | 01:29 PM
moe's Avatar
moe
Default RE: Air Conditioning Filter
i think its a micro filter.i see them changed every once in awhile.i'll check for ya.
Old Mar 27, 2008 | 01:34 PM
moe's Avatar
moe
check this brother!
DESCRIPTION
Some models are equipped with a particulate air filter (1) that helps purify the outside air entering the HVAC housing. The filter is mounted in the HVAC housing, behind the glove box.
The particulate air filter element is the same size as the A/C evaporator to ensure ample filtering capacity. A removable door on the HVAC housing provides easy access to the particulate air filter element for replacement.
The filter should be replaced at least once a year or every 24,000 km (15,000 miles) and checked if heating-A/C system performance seems lower than expected. The particulate air filter is labeled with an arrow (2) to indicate the direction of air flow through the filter.
Old Mar 27, 2008 | 01:36 PM
moe's Avatar
moe
how to.......
REMOVAL
1.
Locate the particulate air filter door (1) on the bottom of the HVAC housing (4) near the glove box area.
2.
Slide the air filter door latch (2) from the closed stop (3) toward the rear of the vehicle until it contacts the open stop (5).
3.
Pull the air filter door straight downward to disengage it from the HVAC housing.
4.
Reach through the opening of the HVAC housing and pull the particulate air filter element straight downward and out of the HVAC housing.
Old Mar 27, 2008 | 07:56 PM
lidxfld's Avatar
Moe...great post. Thanks
Old Mar 28, 2008 | 06:10 AM
goldsmi's Avatar
Old Mar 30, 2008 | 09:57 AM
jamie1's Avatar
You can always take your favorite furnace filter and cut it to fit. You could get 3 filter from that. I personally have not done that,as I'm not that cheap.[sm=smiley2.gif]
Old Mar 30, 2008 | 02:47 PM
indept's Avatar
I would think you could just remove the filter altogether & run the system without it.
Old Mar 31, 2008 | 12:05 PM
ssstw1's Avatar
Only $22.28 +tax from Advance Auto Parts:
http://www.partsamerica.com/productd...tNumber=C35494
Old Apr 2, 2008 | 02:54 PM
moe's Avatar
moe
never had filters when we were kids.lucky my dads car had full working exhaust.
