Air Conditioning Filter
Old Jun 6, 2008 | 08:26 AM
mikeeyd's Avatar
Default RE: Air Conditioning Filter
Does the glove box door need to be removed? How do I access the filter?
Thanks.
Old Jun 6, 2008 | 01:28 PM
levistar's Avatar
The glove box door does NOT have to come off. Look under the dash on the pass side. You will see an access door. Slide the lock back,remove the door and pull the filter out. See the prev posts. Read the instructions that come with the new filter on how to put it back in.
Old Sep 6, 2008 | 11:09 AM
stillbill55's Avatar
My Front Passenger floor is flooding from AC. Will a new Filter help? Is there a drain hole that needs cleaning? Where is it? I get water on the ground still.
Old Feb 26, 2009 | 04:03 AM
rs_filter's Avatar
The single most important thing you can do to keep your air conditioning and heating system working efficiently is to make sure the air filter is matched,
____________________
Furnace Filter
Old Feb 26, 2009 | 07:37 AM
  #15
goldsmi's Avatar
Napa 4864
Old Nov 6, 2010 | 09:14 PM
  #16
ecenur's Avatar
Originally Posted by jamie1
You can always take your favorite furnace filter and cut it to fit. You could get 3 filter from that. I personally have not done that,as I'm not that cheap.[sm=smiley2.gif]
Do you think it would be something easy to do, I'm looking into doing this it seems like a good way to save money, but I do not want to waste time on something that isn't going to work properly might as well purchase one from the store.
Old Apr 28, 2014 | 04:38 AM
  #17
ciprianf's Avatar
Default Chrysler Pacifica cabin air filter location
If you want to change by yourself cabin air filter location is very easy. Is necessary to follow some simple steps. I found here one article how to do this with picture Chrysler Pacifica cabin air filter location
Thanks!
mascu
Jun 9, 2009 06:28 PM
pepe
Jul 7, 2007 05:11 PM
CJ
Jun 9, 2007 09:35 PM
mckzach
Jun 6, 2007 03:28 PM
oakbri
Dec 13, 2006 11:27 PM
