Another Check Engine Light Thread
I have a 2004 Pacifica with 112,000 miles. The check engine light is on, and stays on. The EGR valve has been replaced, new gas cap is on the car, and the EVAP sensor in the gas tank has been replaced. The light shut off for 24 hours after the cap and EGR valve were replaced, just long enough for the car to pass emissions testing. Now it's back on again. The car otherwise runs fine. Does anyone have any ideas?
P0440-GENERAL EVAP SYSTEM FAILURE
When Monitored and Set Condition:
When Monitored: Engine Running. Fuel Level greater than 12%. Ambient Temperature
between 4°C and 32°C (39°F and 89°F)
Set Condition: The PCM does not see the NVLD swtich close during the medium/large
leak test. The PCM then will increase the vacuum supply to the EVAP system by
increasing flow through the EVAP Purge valve. If the switch does not close with an
increase in vacuum an error is detected. Two Trip Fault.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
VISUAL AND PHYSICAL INSPECTION
EVAP PURGE SOLENOID VACUUM SUPPLY INSPECTION
EVAP PURGE SOLENOID
NVLD SWITCH OPERATION
GROUND CIRCUIT OPEN
NVLD ASSEMBLY
NVLD SWITCH SIGNAL CIRCUIT OPEN
EVAPORATIVE EMISSION LEAK DETECTION
PCM
POSSIBLE CAUSES
EVAP PURGE SOLENOID
GROUND CIRCUIT OPEN
NVLD ASSEMBLY
PCM
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
Dee Perk
Mar 19, 2009 09:13 PM
