Brake pedal violently vibrates
Old Nov 6, 2011 | 10:36 PM
bambuzas's Avatar
Default Brake pedal violently vibrates
Hello,
The brake pedal of my 2006 Pacifica violetly vibrates when braking. There has been new tires installed, rotors and brakes changed. Brake light came on just two times for a few second and then went away. It has 90K miles FWD.Please help !!!!
Old Nov 12, 2011 | 09:33 PM
bambuzas's Avatar
F***ing american cars
Old Nov 12, 2011 | 10:15 PM
is this a general thing that only American cars have warped rotors or something?
Old Nov 19, 2011 | 11:36 AM
LeoM's Avatar
Default Vibration
Have you tried to retorque the lugs to the proper torque? I have seen people who don't know how to install tires correctly and just tighten the lugs till their impact gun stops turning.
I would try and jack it up loosen all the lugs and torque them in a cross pattern starting at 30' lbs. and then 60' lbs and final 95ft. lbs.
Old Apr 9, 2012 | 08:32 PM
Debbie Gary's Avatar
Default ABS brake shudder
Also have issues with violent shudder of ABS brake system. Only happens going down hill at high speeds, freeway speeds. Just a tap on the brake causes the ABS braking to kick in and the whole car to shudder. Is their a sensor that detects the angle the car is driving? if you are on the flats driving freeway speeds it doesn't happen.
Old Apr 10, 2012 | 09:16 PM
Raindrop's Avatar
There are 4 ABS sensor which detects speed and\or spin of the wheel but do not detect angle of descent of car. May be wires on on of the ABS sensor anr loose or stripped. If you have not replaced the ABS sensors before, then may be one of the ABS sensor is bad.
Is ABS light is on?
monsterdub
May 5, 2024 11:10 AM
key5000
22
Oct 14, 2017 11:52 AM
Mark
Dec 10, 2014 09:13 AM
procraneop
Aug 7, 2014 07:55 PM
posjr
Jan 18, 2007 01:52 AM
