A/C Expansion Valves Screws_2005 Pacifica
Old Mar 10, 2018 | 05:06 PM
djetelina's Avatar
Default A/C Expansion Valve Screws_2005 Pacifica
I have an upcoming job to replace the A/C Expansion Valve on a 2005 Chrysler Pacifica. There are two (2) screws that hold the Expansion Valve to the Evaporator. Viewing the valve is almost impossible due to its location in the firewall, can anybody shed any light on if these 2 screws are Phillips, Allen head, star head, hex head, etc??
Many thanks! DJ
Old Mar 16, 2018 | 02:45 PM
djetelina's Avatar
OK, I just changed out my Expansion Valve, so I will answer my own question. The 2 screws are Torx, sized T25.
There is a stud on the Expansion Valve that comes out to allow easy access to 2 Torx screws. To get the stud out a small FEMALE Torx socket is needed.
Regarding the two (2) Torx screws, the screws are steel and screwed into the aluminum evaporator bracket. My screws seemed to have been over-torqued at the factory, the female threads in the aluminum bracket were in pretty bad shape. I backed screws out s-l-o-w-ly and sprayed WD-40 behind the bracket onto the screws while backing out. Wire brushed the screws and ran a M5-.8 nut over screws to clean aluminum debris from the screw threads. Was able to salvage my screws/threads and my A/C system is back up and running!
andyb2000
14
Jul 27, 2013 07:58 AM
diemz
Oct 10, 2011 09:00 AM
CARNUTBOB
Aug 10, 2011 09:25 AM
shnurik
Jul 31, 2009 11:41 PM
monbenkey
Jul 29, 2008 04:11 PM
