Camshaft Positioning Sensor location
Old Nov 4, 2022 | 10:06 AM
RSDADDY141's Avatar
Default Camshaft Positioning Sensor location
Hi there. I'm new here so bare with me.
I have a question.
Where can I locate the Camshaft Positioning Sensor on a 2008 Chrysler Pacifica 6 cylinder. Is if near the alternator or on the right side of the engine?
Any help would be appreciated. Thanks!
-J
Old Nov 4, 2022 | 10:24 AM
RSDADDY141's Avatar
Default Engine size
I should mention it's a 4.0 v6
Old Nov 4, 2022 | 12:56 PM
stephenjxn's Avatar
Old Nov 4, 2022 | 02:02 PM
RSDADDY141's Avatar
Default Thanks!
Originally Posted by stephenjxn
Thank you!
Old Nov 27, 2022 | 01:41 PM
RSDADDY141's Avatar
Default Still the same issues...
Changed the cam AND the crankshaft position sensors,still cranks over slow.
It runs as it did before the cranking problem so I'm at a loss...suggestions?
Old Nov 27, 2022 | 09:07 PM
FIREM's Avatar
Hope you saved the old sensors and or used OEM replacements. We have learned over the years that Aftermarket ones do not last. (Cheap magnets loose their magnetism)
Sensors have nothing to do with slow cranking speed. Battery, Cable Connections, grounds are the usual suspects. Starter or binding engine internals remotely suspect but test everything else first.
If its cranking good but slow starting,
fuel pressure testing would be the place to start
Old Nov 27, 2022 | 09:24 PM
RSDADDY141's Avatar
I was going off of codes. Ill check everything you suggested. Thanks.
Old Nov 28, 2022 | 04:58 AM
FIREM's Avatar
What Codes do you still have ?
Old Nov 28, 2022 | 08:10 AM
RSDADDY141's Avatar
Default C121c
Old Nov 28, 2022 | 08:11 AM
RSDADDY141's Avatar
Default Po340
