Camshaft Positioning Sensor location
Old Nov 28, 2022 | 10:52 PM
"still cranks over slow." a cam or crank sensor will not cause the engine to spin over slow. that would be a wire issue a starter issue something like that. as for the 340 did you clear the codes and that same one came back?
Old Dec 2, 2022 | 12:32 PM
RSDADDY141's Avatar
Default MAP sensor
So I went and replaced the "New"sensors again and still the same codes.
got the RedLightning Bolt of Death,it started blinking, checked MAP sensor was loose so i ordered another one. Cross your fingers!
p.s. Lightning bolt went away as soon as i wiggled the MAP sensor...
Old Dec 2, 2022 | 12:37 PM
RSDADDY141's Avatar
Default Yep
Codes
I did clear the codes and they came back.
Old Dec 3, 2022 | 12:28 PM
well first you replaced the cam and crank sensor due to slow start yes? did you have the codes before hand ?
Old Dec 3, 2022 | 12:31 PM
  #15
RSDADDY141's Avatar
Yeppers!
Old Dec 6, 2022 | 08:28 PM
  #16
what brand sensors did you use?
2007Pacifica4L
Dec 27, 2019 07:55 PM
kelcig69
Mar 24, 2017 10:32 AM
Cargal
Jan 6, 2015 01:50 AM
rycb25
Dec 13, 2010 06:56 PM
funjon1
Jun 25, 2008 07:01 PM
