Chrysler Pacifica Condensor Question
Old Jun 3, 2012 | 02:05 PM
scllow69eneiskeen's Avatar
Default Chrysler Pacifica Condensor Question
I have a 2007 Chrysler Pacifica Touring Edition. I bought it a few months ago. had the ac charged and it stayed cold for a few days, took it back in they recharged it and put in a dye kit, said it was leaking from the condensor. I am trying to replace the condensor. I have heard that the ac drier, condensor and the transmission cooler is all one part. Is this true?
If this is not true, can you guys link me to the parts i need?
If it is true would this part work?CONDENSOR
or
Condensor1
Thanks.
Old Jun 3, 2012 | 02:15 PM
TNtech's Avatar
Yes, that is correct. Some condensers incorporate the trans cooler into about a 1/3 portion of the unit. The drier is a looong skinny cylinder unlike past driers that have been short and fat.
Old Jun 3, 2012 | 02:28 PM
If that is the case would that first condensor and this part work?
This Part?
and this
This part?
Old Jun 3, 2012 | 05:36 PM
open up the page and read the little notes to the far left
Old Jun 3, 2012 | 07:07 PM
TNtech's Avatar
The A/C condenser (1) is located in the front of the engine compartment behind the front fascia. The A/C condenser is a heat exchanger that allows the high-pressure refrigerant gas being discharged by the A/C compressor to give up its heat to the air passing over the condenser fins, which causes the refrigerant to cool and change to a liquid state.
The A/C condenser is equipped with two fittings (2) for the refrigerant lines, an integral automatic transmission fluid cooler (3) with quick-connect fittings (4) for the transmission fluid cooler lines (5) when equipped with an automatic transaxle, mounting brackets (6) that attach the condenser to the radiator (7) and an integral receiver/drier (8)
The A/C condenser may be removed for service without removing the radiator from the vehicle.
Andrew Stutzman
Feb 12, 2015 07:48 PM
Vmaxxer
Sep 2, 2014 04:53 PM
kkc
May 4, 2013 07:02 AM
70TorinoGt
Jul 14, 2008 06:00 PM
crimpshrine
May 12, 2008 10:16 PM
