Cruise control inoperable
Old May 22, 2024 | 12:29 PM
Mike62's Avatar
Default Cruise control inoperable
Hi, I have a 2004 Pacifica, When I turn the cruise control on, it will not engage but the cruise control lights up on the dash. The car has sat for many years without being driven. I was just wondering if there was a fuse that could be causing the problem. I found the fuse box under the hood but nothing specifying the cruise control. Is there a fuse box under the dash in this car also? Is there a component I should be looking at? I do not have a repair manual for the car so I wouldn't even begin to know where to start looking.
Old May 22, 2024 | 02:24 PM
make sure there is vacuum going to the servo that controls the cruise.
Old May 22, 2024 | 03:17 PM
Mike62's Avatar
thank you for the info. I will look for the info of where the servo is located. I thought like my ford there would be a pressure switch on the brake reservoir but there isn't one.
Old May 22, 2024 | 03:43 PM
Mike62's Avatar
I did find a small vacuum hose busted off maybe someone knows where it attached to? Looks like the nipple busted.
Old May 23, 2024 | 12:58 PM
that would infact be for your cruise control there ill be a matching one to the servo.
Old May 23, 2024 | 01:26 PM
Mike62's Avatar
Thank you for the information. I'm going to have to buy a repair manual for this car. It's the 1st Chrysler I've ever owned and I do not know where anything is on it. Thanks again for the help, if I find when it broke off of maybe I can epoxy it back in place or something? IDK.
Old May 23, 2024 | 07:08 PM
Mike62's Avatar
Ok, there is a rubber T connector. It has 2 black lines and 1 red line. The black line that goes to the valve cover is the damaged one.
Old May 26, 2024 | 08:28 AM
repair that line the other one likely goes inside for a vac controlled hvac door
harlandejohnson
Nov 14, 2022 01:55 PM
krhall3273
May 10, 2021 04:53 AM
thundergod66
May 20, 2013 12:49 PM
TEHCUB
Apr 11, 2010 09:06 AM
morowitz1
Mar 5, 2009 02:41 PM
