Dashboard Light Replacement
Old May 6, 2010 | 10:09 PM
CRCError1970's Avatar
Default Dashboard Light Replacement
Ok, I give up. I've Googled every term I can think of and I cannot find any reference for replacing dash lighting on the Pacifica.
I've got one bulb out in the Heat/AC panel and it is bugging the heck out of me and I *really* don't want to take it to the dealer to get it fixed.
Old May 6, 2010 | 10:43 PM
The A/C-heater control cannot be repaired. If faulty or damaged, the entire unit must be replaced. The control ***** are available for service replacement
Old May 7, 2010 | 08:15 AM
avissvcmgr's Avatar
I copied and pasted from the T&C section of the forum. Hope this helps.
Page 1 of 2 1 2 >
Thread Tools Search this Thread Rate Thread
#1 01-12-2008, 03:57 AM
finlandmauri Join Date: Dec 2007
T&C 2001: Climate Control backlights
It seems that the light bulbs that light up the climate control buttons went out. Does anyone know what size they are? Can I just get them at Autozone? Thanks!!
finlandmauri
Find all posts by finlandmauri
Add finlandmauri to Your Contacts
#2 01-12-2008, 01:15 PM
CHRYSLER TECH
Super Moderator Join Date: Mar 2006
RE: T&C 2001: Climate Control backlights
I dont think U can replace any bulbs back there
__________________
14 Plus year Chrysler,Dodge,Jeep Tech I work at a dealer and I have a mobile repair service in ATLANTA. KKeller608@aol.com
Master Electrical,Master Engine Performance,Master AC,
Master Body Mechanical,Master Brakes.2 year associates degree for Chrysler.
Kevinsmobileservice.com
New business please take a look at it for me Serving Georgia natural gas and Texas for electricity.
http://kevinkellerenergy.igniteinc.biz
CHRYSLER TECH
Send a private message to CHRYSLER TECH
Send email to CHRYSLER TECH
Visit CHRYSLER TECH's homepage!
Find all posts by CHRYSLER TECH
Add CHRYSLER TECH to Your Contacts
#3 02-21-2008, 09:03 PM
alparsalan Join Date: Feb 2008
I changed the light bulbs in the climate control. The climate control is expensive and to buy a new one just because the light doesnt work is unfair. Anyways, these bulbs are not available at any auto shop. You can open the climate control and remove these bulbs (seven or eight in total). They are soldered on the board so you will require a soldering gun to remove them. The bulbs are like small LED's but are regular bulbs. Take one of the bulbs that you have removed from the climate control to any electronic shop (not an auto shop) and ask them to give you a replacement with similar specifications. They are very cheap to buy. I changed mine more than 6 months ago and they are working fine.
You can even change bulbs in the switches that are located in the center console. These bulbs are just glued to the board and with time the glue comes off and the bulbs stop working. You can change these bulbs and solder them so that they never come loose.
alparsalan
Find all posts by alparsalan
Add alparsalan to Your Contacts
#4 02-23-2008, 03:07 PM
fullcourt Join Date: Feb 2008
how hard is it to remove the climate control. Do you have to take the whole center dash off?
I had this same problem, and the dealer somewhat fixed it. A few of the lights are still not working. There was a short in the panel dimming control.
Stupid of Chrysler not to use LEDs that last forever.
fullcourt
Find all posts by fullcourt
Add fullcourt to Your Contacts
#5 02-24-2008, 04:46 PM
Rick99
Senior Member Join Date: Dec 2007
It's easy to remove the center dash trim. (assuming we're talking 01-07) Remove your cup holder, use a flat-head screwdriver or your fingers to pull off the thin strip of trim just above where the cup holder was. Remove the two phillips-head screws, get your fingers under the metal, pull it up and work your way around the trim from bottom to top popping the trim off. With the trim pulled away, remove all of the electrical connectors-- remember to slide the little red tabs to the side before pressing the release tabs and pulling on the connectors to get them out.
The climate control will be attached to the trim.
Rick99
Find all posts by Rick99
Add Rick99 to Your Contacts
#6 09-18-2008, 12:35 PM
avissvcmgr
Junior Member Join Date: Apr 2008
Bulbs from anelectronic shop as in Radio Shack? Any specific recommendations?
avissvcmgr
Send a private message to avissvcmgr
Find all posts by avissvcmgr
Add avissvcmgr to Your Contacts
#7 02-01-2009, 08:48 PM
big walt
I have a 2001 T&C and I read your post and removed and opened up the climate control. I noticed that there are seven or eight small yellow bulbs down where the ***** are at and they work fine. There are also other bulbs on this circuit board and none of mine work. My question is When you changed your bulbs did you change the yellow bulbs or the other ones and were any of yours working.
big walt
Find all posts by big walt
Add big walt to Your Contacts
#8 03-02-2009, 01:55 PM
hawken
Junior Member Join Date: Mar 2009
I am having the same issue with one burned out light bulb in the ATC control panel. I saw both the little yellow LED's and the larger incandescent barrel-shaped bulbs. It was the barrel-shaped bulb that burned out on my board. I will take it to a local electronics shop and have them weigh-in on replacing the bulb (de-soldering and re-soldering a replacement bulb).
I can't believe Chrysler would design the panel without serviceable bulbs (I do not think buying a new circuit board from Mopar or having to resolder a bulb is "serviceable"). Geez.
hawken
Find all posts by hawken
Add hawken to Your Contacts
#9 03-02-2009, 10:57 PM
superfast
Junior Member Join Date: Feb 2009
I use the mini lamp from Radio Shack, on my 01 town and country climate control. it's been a month now and it's still work good... here's the part number from Radio Shack 272-1092 it's in a package of two mini lamp....
superfast
Find all posts by superfast
Add superfast to Your Contacts
#10 03-03-2009, 08:25 PM
actd
Senior Member Join Date: Nov 2008
Is there any reason why a 12v LED can't be used? Maplins sell these in yellow for about 40 pence?
I've noticed on mine that the lights on the driver/passenger slide controls aren't working - are these lights on the boards also or are they within the switches themselves?
actd
Send a private message to actd
Find all posts by actd
Add actd to Your Contacts
Old May 7, 2010 | 06:08 PM
Thanks, I didn't think to search for other models besides the Pacifica.
I've never had a problem with the so called "non user-serviceable" parts in my car. I've been a motorhead since 1982... My first project was a WWII Era Halftrack with a quad 50 turret. I'm used to dealing with making things work when stock parts are not available.
It kinda honks me off that a bulb would designed to not be easily replaceable however my idea to replace all the lights in my dash with SMD LEDs.
Old Jun 1, 2010 | 12:04 AM
kwright's Avatar
Did you ever find out what bulbs to buy to complete this task? I too have bulbs out on the left and right side second row down on the dual zome temp control.
Old Jun 1, 2010 | 12:06 AM
kwright's Avatar
Do these bulbs have a colour sleeve over a white bulb or are they coloured bulbs?
bryamon
Aug 17, 2019 12:54 PM
70TorinoGt
May 4, 2017 01:47 AM
Sycamore_2
Sep 19, 2008 12:50 AM
urbs4
May 3, 2008 12:12 AM
mascu
Jun 15, 2007 08:25 AM
