Driveline fluid change, help.
Old Dec 2, 2007 | 08:30 PM
Aeiceman's Avatar
Default Driveline fluid change, help.
I'm a proud new owner of a '04 AWD. After reading the owners manual it claims the transfer and some sort of clutch fluid needs changing every 30k or so. Is this true? Can I do this myself? Thanks in advance.
Old Dec 3, 2007 | 10:45 AM
moe's Avatar
moe
Default RE: Driveline fluid change, help.
do youhave a awd caravan.? if so heres some info.moe
moe's Avatar
moe
Old Dec 3, 2007 | 10:46 AM
moe's Avatar
moe
STANDARD PROCEDURE - DIFFERENTIAL ASSEMBLY FLUID CHANGE
The drain plug (Differential Drain Plug) for the differential assembly is located in the bottom of the differential assembly case, toward the rear of the unit.
The fill plug (Differential Fill Plug) for the differential assembly is located on the rear of the assembly case.
The correct fill level is to the bottom of the fill plug hole. Be sure the vehicle is on a level surface, or is hoisted in a level manner, in order to obtain the correct fill level.
[ol][*]Raise the vehicle on a hoist.[*]Position a drain pan under the differential drain plug (Differential Drain Plug).[*]Remove the drain plug and allow the fluid to drain into the pan.[*]Install the drain plug and torque to 35 N·m (26 ft. lbs.).[*]Re-position the drain pan under the differential fill plug.[*]Remove the differential fill plug (Differential Fill Plug).[*]Using a suction gun (Filling Differential) or equivalent, fill the differential assembly with 0.7 L (1.48 pts.) of Mopar® Gear and Axle Lubricant (80W-90).[*]Install the fill plug and torque to 35 N·m (26 ft. lbs.). [/ol]
Old Dec 3, 2007 | 02:48 PM
Aeiceman's Avatar
Pacifica,I thought that was the only vehicles we talked about on this forum?
Old Dec 3, 2007 | 04:14 PM
moe's Avatar
moe
it looks the same under the car.drain is on bottom.fill is in top.moe
Old Dec 3, 2007 | 04:39 PM
moe's Avatar
moe
sorry i didn't look i just click on new post and see if i can be of help.my/bad,moe
alan509
Aug 2, 2010 05:10 PM
jake763
Jul 17, 2009 02:08 AM
Pacifica3.82007
Feb 26, 2009 08:16 PM
Dave
Feb 24, 2008 02:48 PM
Dave
Feb 23, 2008 09:54 AM
