front end rattle code p0457
Old Apr 3, 2018 | 07:17 PM
corvairbob's Avatar
Default front end rattle code p0457
ok there ahs been some talk about the pacificas having a rattling noise from the front end when hitting bumps. well mine did to. i found this rattle to be the rubber sway bar mounts. the rubber gets worn by the bar moving up and down in the mount. maybe there should ahve been a tsb on this to tell people to put lube on the bushings.
anyway it ahs beed like 6 weeks and the noise have not returned so i'm posting my fix. this fix will not be a perminate fix but should last long enough for you to get new bushings or just get nes bushings and install them. i used a seection of heater hose and loosened the bolst and shoved the section of hose in between the bar and the bushing. the bolts that hold the bushing to the frame are not easy to remove. mostly rusted in but they did loosen. if you can spray them with some oil do it.
or ahve the dealer replace them for you, all i cans y is with all the people saying the repairs the dealer did did not work i checked out the area and found the bushing were loose as a goose. you can actually move them by hand.
good luck
code p0457 and the others in the evap code section turned out to be the nvld. it had a bad switch inside the unit and as soon as i replaced that valve. easy job the codes just went away. been 6 weeks and no codes. so for 40.00$ and an hour of your time jack it up securely remove the valve almost does the job itself no tool needed for me. part was just clipped on pull off the hoses remove the wire clip and replace it. done.
good luck on that one.
rtp
May 25, 2024 07:40 PM
rbar123
Mar 25, 2024 06:50 PM
Annyvaal
Jan 24, 2018 11:28 PM
corvairbob
Dec 20, 2017 12:26 PM
steve392
Dec 21, 2008 07:45 PM
