How to check computer fault codes
Old Aug 17, 2009 | 12:15 AM
Virglijus's Avatar
Default How to check computer fault codes
Hello All,
I am the new owner of 2007 pacifica touring 4.0 l FWD. I wanted to check if there are not any computer fault codes and tried to do "key dance" but it did not work. Is it posible to check codes without OBD scaner?
Thanks...
Old Aug 18, 2009 | 08:56 AM
do u have a check engine light on? are u experiencing anything wrong?
Old Aug 18, 2009 | 11:56 AM
Virglijus's Avatar
Yes, check engine light is on.
Old Aug 18, 2009 | 03:10 PM
if the key dance did not work then yes U will need a scanner that is can bus
Old Aug 20, 2009 | 02:51 PM
Qckslvr's Avatar
All right, I'll bite. What's the "key dance"?
Old Aug 20, 2009 | 09:47 PM
turn the key on and off 3x
Old May 20, 2014 | 02:30 PM
Tamban's Avatar
On our 05, set the E brake, put into neutral, select trip odometer, start at key ON, off, on off on off. wait for it... that worked for this model...
Jfizzle
Feb 22, 2020 04:37 PM
Munro
11
Feb 24, 2014 01:13 PM
Barbara 2
Nov 15, 2012 12:24 AM
stewartsoftware
Apr 17, 2011 03:22 PM
JayBee1230
Feb 26, 2011 09:33 PM
