Interior lights not turning off?
Anyone run into this problem? Just happened this morning. All of the lights stay on when driving and do not turn off when vehicle is off and locked. What could be the cause of this? Fuse issue, or door latch sensor?
What are you driving?
Can you re-post with the model and year of your vehicle?
First thing to check is the switch that is used to manually turn on the interior lights. I'm not familiar with your Pacifica but it's often the same as the instrument panel dimmer switch, just turned to its extreme position. Check your owners manual. It could be a door latch switch but that's the same switch that activates the "Door Ajar" warning. It's not going to be a fuse. The only thing a fuse can do is blow, then no electricity can pass and whatever the fuse is protecting won't work.
HighAndDry
Aug 7, 2012 03:19 PM
chriswest3684
Jun 15, 2011 08:52 AM
Jeremy2005
Sep 1, 2005 01:30 AM
