Intermittent ESP/BAS lights
Old Mar 17, 2011 | 12:12 PM
tamazeen's Avatar
Default Intermittent ESP/BAS lights
For the past couple of weeks the ESP/BAS lights come on in my wifes car after about 10 minutes of driving. They will reset after car has been turned off & restarted. Also noticed that the steering wheel is 10 degrees counter clockwise when the car drives straight, will pull to the right when I straighten the steering wheel. Any relationship to the steering wheel/tire alignment & the ESP/BAS lights?
Any help would be appreciated
Thanks!
Old Mar 17, 2011 | 06:47 PM
Djinn-n-Tonic's Avatar
Absolutely..........
Why is the wheel off-centered..... A collision,? A Botched Alignment attempt?? severely worn steering components???
There is a sensor that measures steering angle....It is usually in the base of the steering column, or integral to the clockspring. If While the car is going straight, the angle sensor registers a left turn.
As your computer looks around and says ...A left turn???? but no body roll?? and no differential in wheel speeds from ABS? ...Something is wrong....and Until I figure out what it is...I will do NOTHING......
ABS , ESP, And BAS default , and the warning lamps come on....
Old Mar 17, 2011 | 07:53 PM
busboy4's Avatar
Good info Djinn,
but this one stumped the dummy...what is/are ESP BAS?
Old Mar 17, 2011 | 10:43 PM
Electronic stability program/ Brake assist system.......in short....TRACTION CONTROL
spinedoc2304
Aug 5, 2018 10:08 PM
kevcot
Jul 24, 2016 12:21 PM
batman99
Sep 14, 2013 05:53 PM
blackoutken
9
Dec 29, 2012 01:26 AM
bgborden
Mar 7, 2010 09:15 AM
