meltdown
Old Sep 11, 2014 | 02:51 PM
pac8911_'s Avatar
Default meltdown
pcm harness melted due to zero grounds after replacing it ...will the software need reflashing... throwing 6 codes that i believe are due to faulty PCM
Old Sep 11, 2014 | 10:20 PM
flashing a PCM is updating teh software so if u want to rewrite the software that's already in there go ahead it wont do any good. and what codes and what year pac?
Old Sep 12, 2014 | 09:17 AM
pac8911_'s Avatar
0627. 0688. 2068. 0517. 0533. 0073. All relays replaced and fuel pump as well
Old Sep 12, 2014 | 09:18 AM
pac8911_'s Avatar
2004 awd 3.5
Old Sep 12, 2014 | 01:19 PM
ok so whats this? pcm harness melted due to zero grounds after replacing it
u replaced
the engine harness and why?
Old Sep 12, 2014 | 01:36 PM
pac8911_'s Avatar
It runs and revs in all positions but stalls in drive but also if you feather pedal the gas you can get it going but after ten minutes of driving it it will start to act up and die then back to not starting but turns over fine then leave it for a week it starts surprise and duplicate the same thing ... I'm thinking the meltdown spiked enough to hit the PCM and scrambled it s software
Old Sep 12, 2014 | 05:03 PM
pac8911_'s Avatar
The harness melted on the previous owner I have now replaced it and that's how the car is acting up in its current condition
Old Sep 12, 2014 | 09:29 PM
ok then id put a PCM in it ones that's already got the software and plug and play
Old Sep 12, 2014 | 10:12 PM
pac8911_'s Avatar
So you don't recommend re flashing just get a different one is that because the old one might not receive the software ...doesn't a new one have to be matched to my vin #??
Old Sep 13, 2014 | 12:07 AM
u can do what u want its your car.
