No high beams! Help needed
Old Nov 27, 2016 | 07:22 AM
quato79's Avatar
Default No high beams! Help needed
Hi I am new to this forum,I have Chrysler Pacifica 2005 3.5 Touring
My high beams suddenly stopped working, low beams are ok but whatever I switch to high not work,I measured the voltage on the high beam wire there is constant 3-4 volts no matter I switch the high beam switch.I have scanner I scan the BCM make actuation test for the stick on the steering wheel it shows that it works,the high beam indicator on the dash also shows, checked the ground its ok,cannot figure out whats going on?
Regards,
Ekremsky
Old Nov 27, 2016 | 08:47 AM
quato79's Avatar
Hi I just figured it out, the problem is solved!
Old Apr 16, 2017 | 07:47 AM
janex's Avatar
pacifica high beams not working unless your engine is working
Old Oct 10, 2017 | 10:25 PM
Grant Lacombe's Avatar
What did you find that was the problem with your high beams ?
Old Sep 1, 2019 | 10:44 AM
Matthew Bodkins's Avatar
Have the same issue, what worked?
Rally Smith
Feb 3, 2016 10:01 PM
Big_Rob
Nov 25, 2012 12:17 PM
lmekic06
Nov 13, 2011 03:52 PM
leortiz
Other
Sep 5, 2011 02:37 AM
ajs42548
Jan 19, 2011 01:45 PM
