No juice to outlets
Old Oct 4, 2009 | 03:06 PM
471Magnum's Avatar
Default No juice to outlets
The auxilary power outlets on my 07 AWD Touring have ceased to function. Only the unswitched one in the dash works.
Fuse checks out okay. Got power to the terminals in the fuse box (both switched and unswitched).
Before I tear apart the IP looking for a bad connection, I'd like to hear if others have had the problem and what your solution was.
Old Oct 5, 2009 | 12:54 PM
Sierrasan's Avatar
Have you checked the accessory relay, it drives the switched outlets?
Old Oct 5, 2009 | 05:20 PM
471Magnum's Avatar
Is that located under the hood on the fuse panel?
Old Oct 6, 2009 | 02:11 PM
Sierrasan's Avatar
In the same box as the fuses.
Old Oct 10, 2009 | 06:55 PM
471Magnum's Avatar
I think I found the problem.
There is juice in the fuse panel to the selectable outlet(s), but fuse 26 (non-selectable) is MISSING!!?!
I was thinking the multiple auxiliary outlets were the selectable, so I didn't even look for the other fuse.
I have no idea where the missing fuse went. I'll have to swing past the auto parts store tomorrow and grab a fuse.
Old Oct 11, 2009 | 06:37 PM
471Magnum's Avatar
Brain fart. What I though was an open fuse 26, was actually slot 27, which is a spare.
So I'm back where I started. Still no juice to the accessory outlets.
And yes, the assy relay is working. I'd be having many more problems if this wasn't working.
Old Oct 13, 2009 | 02:01 PM
Sierrasan's Avatar
There is an accessory relay that only runs the switched outlets and nothing else.
Old Oct 18, 2009 | 05:15 PM
471Magnum's Avatar
If so, please let me know in what slot it resides. I sure as heck can't identify it.
I'll give you a hint: It's not #57
Attached Thumbnails No juice to outlets-p1040503.jpg   No juice to outlets-p1040504.jpg   No juice to outlets-p1040505.jpg
Old Oct 26, 2009 | 03:38 AM
Neretees73's Avatar
Yea, I was going to say exactly what BP said, but he beat me to teh punch.
Its awesome, Juice, so I give it 4/5
Old Oct 29, 2009 | 10:28 AM
gracia12's Avatar
there is problem with your relay..just check it once and then if problem get it repaired...
