P0334 (cam sensor) and alternator pulley noise
Old Aug 30, 2014 | 04:43 PM
myf16's Avatar
Default P0334 (cam sensor) and alternator pulley noise
My 2004 Pacifica with 105k miles has a noisy alternator pulley (especially when cold) and it hesitates once in a while, sometimes with a code P0334.
Since the cam sensor is right under the laternator, I figure I should just change them both and hope for a fix. Is there anything else I should check first?
I know I need to buy a sensor from a Chrysler dealer rather than aftermarket. What do you folks recommend for alternators via Amazon or eBay?
Old Sep 25, 2014 | 09:59 PM
myf16's Avatar
I bought a new alternator and a Chrysler cam sensor both from ebay. I am thrilled with the results.
No more pulley noise at all. That's as I expected.
What I did not expect was a noticeable improvement in smoothness of shifting. Apparently even when it was not throwing an error code the old cam sensor was causing trouble. I didn't know it had anything to do with helping the computer shift but there must be some role there.
Old Sep 25, 2014 | 10:02 PM
myf16's Avatar
Replacing the alternator and cam sensor took about 1.5 hours. I used the youtube video which explains how to release belt tension.
Pop45
Aug 15, 2014 03:26 PM
Pop45
Jul 16, 2014 10:01 AM
estrika
14
Mar 29, 2014 08:53 AM
skdacci
Sep 28, 2012 12:29 AM
Constant
Oct 30, 2011 11:48 PM
