P0344 and PO340 codes
Hello.
I'm trying to diagnose a 2007 Pacifica 4L 2WD.
The symptoms are very intermittent stalling and/or engine "lurching". It usually runs very well.
Everything I've researched on the P0344 and P0340 claim that the issue is almost always the camshaft position sensor, or the wiring. My question is, if the sensor or wiring is bad, then that's not going to cause the engine to occasionally stall or lurch...correct? The one other clue is that the electronic throttle light comes on intermittently as well. I would think that this would be the real clue to the engine troubles. Since the electronic throttle parts are basically all within the throttle body, I was thinking of just replacing the throttle body and seeing what happens.
What do you think?
What do you think?
umoms
Nov 29, 2013 03:52 PM
2003sebring
Feb 19, 2011 07:48 PM
