P0480 and P0305 codes
Old Jul 13, 2015 | 03:24 PM
taz24053's Avatar
Default P0480 and P0305 codes
Ok so here's my problem. Got the codes Friday after I overheated. Today I noticed that both fans were on but still kept getting the 0480 code. My next issue was when I overheated the 0305 popped. Any reason to why pcm detected a misfire in cylinder 5?
Old Jul 13, 2015 | 05:58 PM
ever over heat and engine before? things dont run right when its 270 degrees when its uses to 215
Old Jul 13, 2015 | 06:32 PM
taz24053's Avatar
Actually I have. Melted a piston in my 02 neon. But that's a different story.besides that...doesn't answer my question
Old Jul 13, 2015 | 06:46 PM
taz24053's Avatar
Also, I noticed my coolant tank was empty and I know there is coolant in there...could it be a possible leak?
Old Jul 14, 2015 | 06:53 AM
Royalman's Avatar
Better check you oil make sure it is not milky, possible blown head gasket or crack.
Old Jul 14, 2015 | 06:56 AM
taz24053's Avatar
Will do in a few
Old Jul 14, 2015 | 09:19 AM
taz24053's Avatar
Checked oil...no milky color
Old Jul 14, 2015 | 12:51 PM
Royalman's Avatar
If you refilled coolant tank, it's going somewhere, check for leakage, underneath for bad water pump, hose, even inside for leaking heater core, or if you didn't put enough in getting all of the air out of the system.
Old Jul 14, 2015 | 01:07 PM
taz24053's Avatar
I am coming up on 200k. Might be the pump. When I drive it's fine. Its when I'm stopped for periods of time...
Old Jul 14, 2015 | 01:23 PM
taz24053's Avatar
Ok so I just parked and my coolant tank started filling and started overfilling....is the water pump the bad guy for this?
