Pacifica 2007- Plenum Manifold and Actuator
Old Oct 11, 2014 | 06:59 PM
yes dealer only can only update if like U said they already did then no need to after actuator was replaced
Old Oct 22, 2014 | 03:03 PM
jimbo74's Avatar
the way it sounds, is the OP doesn't think the dealer did do the update even though they said that they did....
am I correct, that if they did a software flash, they have to put a sticker under the hood saying it was reflashed?
Old Nov 22, 2014 | 08:53 PM
ej405@aol.com's Avatar
Default Plenum change
I had code P0306 with vacuum leak (at actuator shaft) so I tried the injector ring placement trick I saw on u-tube it failed so I changed the plenum, plugs and 6 coils, runs like new.
jgstudios`
Aug 6, 2013 09:25 PM
EdOv
Jan 8, 2012 12:25 AM
wylecoyote
Sep 21, 2010 03:55 PM
mm9957
Apr 15, 2010 06:50 PM
muse6638
Oct 9, 2009 09:08 PM
