Pacifica "dogbone" engine mount
Old Aug 6, 2018 | 05:23 PM
quakerj's Avatar
Default Pacifica "dogbone" engine mount
I keep seeing a reference to a dogbone mount on forums, and this dogbone mount is even sold on Rockauto. I recently changed what I thought was all my motor mounts -- the one under airbox, and the two lower mounts. I'd like to replace this "dogbone" mount, but I cannot locate it on the vehicle. Does anyone know where this mount is located? Thanks in advance. I have an 07 Pacifica Limited FWD.
Old Aug 8, 2018 | 07:15 PM
djetelina's Avatar
The only engine mounts, to my limited knowledge, is the 3 that always fail. As mentioned the 2 lower mounts and the one under airbox. Maybe others are referring to the one under airbox as a "dog bone"... Ruff
Old Aug 20, 2018 | 05:02 AM
grbullets's Avatar
The "dogbone" mount is actually called a torque strut and is located on the transmission. You'll be able to see it on the driver side through the wheel well with the wheel off on a 3.5L motor.
. This is an extremely expensive part if you want to use Mopar parts, but aftermarket is pretty cheap...Yes they do have them at Rock Auto.
quakerj
Jul 10, 2018 08:43 PM
grbullets
Feb 14, 2017 03:04 PM
07PacificaLimited
Feb 8, 2017 05:10 PM
grbullets
May 1, 2012 05:19 AM
04_pacifica_4u
Jun 29, 2011 12:03 AM
