Pacifica EVIC
Old Jun 29, 2010 | 09:08 AM
nslack44's Avatar
also looking to see the pictures. if anyone could email me @ nslack44@rcn.com that would help me out tremendously.
Old Jul 25, 2010 | 10:27 PM
russ111's Avatar
Thanks for the information! About 2 hours and less than $6 at Radio Shack and I now have EVIC for the first time since we've owned the car! Only took me 2.5 years to get to a point where I wanted to fix it. Thanks again all.
Old Oct 22, 2010 | 09:35 AM
dank's Avatar
Guess I've been gone for awhile. Good for you russ. How exactly did you do it? I mean is the fuse easy to notice and replace?
Old Jan 6, 2011 | 09:17 PM
rjpete's Avatar
Default can i get a copy the pics too.
I am having the same problem also. I need to see the pics to locate the fuse and take the dash apart.
Old Jan 9, 2011 | 12:12 AM
  #15
Barbara 2's Avatar
Default EVIC Pics
RJPETE, send a email address and I can send some pics and how it was done but in a little bit different way. Thanks. *BW*
Old Jan 9, 2011 | 08:24 AM
  #16
nslack44's Avatar
Barbara2 I still haven't had enough time to rip out the entire dash. I would love to see the other way also.
Nslack44@rcn.com
Old Jan 10, 2011 | 11:18 PM
  #17
Barbara 2's Avatar
Default To Nslack, et all
What we did different was that we soldered wires to each side of the original fuse that was long enough to hang down lower under the dash and connected to a glass fuse holder for easy replacement. Used a quality 1/2 amp fuse only and expected several to blow out while finding the problem since other things are tied into the evic like the problematic tire sensors and the compass and whatever else. Happy to report everything is working ok and not one fuse has blown. I would suggest to not give into the temptation to put in a larger fuse to cure any other problems. The circuit is designed for 500 milliamps so don't create other problems by going to a larger size. Thanks. *BW*
Old Jan 11, 2011 | 08:29 AM
  #18
grayring's Avatar
Barbara2, can you send me an email with the pictures to grayring@gmail.com ?
Old Jan 11, 2011 | 07:45 PM
  #19
dank's Avatar
Hey Barbara, think you could send that to me as well cause I don't really want to go with a larger fuse if it can possibly cause other problems.
kratg@yahoo.com
Thanks,
Dan
Old Jan 11, 2011 | 07:51 PM
  #20
Djinn-n-Tonic's Avatar
Does anyone realize how much of a FIRE HAZARD this is becoming??????
