Problem w/2005 Pacifica fuel gauge
Old Jun 18, 2007 | 03:40 PM
lkwhalen68's Avatar
Default Problem w/2005 Pacifica fuel gauge
I'm a 9 day owner of a 2005 Pacifica with 29000 miles. I filled my tank on day 3 of ownership. On day 7 I left home with over a half tank of gas. I drove 50 miles, stopped, and later restarted my vehicle. My gas gauge showed empty and thevehicle said "15 miles to empty". I knew there was no way the tank was empty, and when Ifueled up, I could only add 9 gallons. After reading numerous (I mean a lot!) of post on many sites, I realize this is a common problem, but I haven't see any recents posts, and the ones I saw stated nodefinitive solutions to the problem. Some time has gone by, and I am wondering if anyone has had this problems and has it successfully resolved, and, if so, how? Ilive in a fairly small town and contacted a local dealer to schedule a service appt. I told the serviceman the problem, and he said I would need to get the vehicle to duplicate the problem before I bring it in, which Iwould rather not do! Hopefully a larger dealer in a town nearby will have experience with the problem, but I would first likesome of myown info to take to theservice department when I make the appointment. Thanks!
Old Jun 18, 2007 | 11:36 PM
Default RE: Problem w/2005 Pacifica fuel gauge
some 05 pac haev fuel pump or PCM software upgrades depends on the build date of the car if u get a pump or a software update. They can tell u or u can give me the last 8 of your vin and i will find out
Old Jun 19, 2007 | 09:58 AM
lkwhalen68's Avatar
Last 8 digits of VIN are 5R270798
Old Jun 19, 2007 | 04:10 PM
the recall has been done with the fuel pump but u are under warranty so take it in and go from there
here is the recalls done thus far
I take it u are the second owner
September 18, 2006 44903 - NIKLES MOTOR CO INC
14500106 - Pump, Fuel/Level Unit-Right si
08141804 - Sensor, wheel speed-Anti-lock 001426 29,050 Miles 2006094 WARRANTY REPAIR August 21, 2006 44903 - NIKLES MOTOR CO INC
08E04181 - Recall E04 001411 29,050 Miles 2006084 RECALL REPAIR August 15, 2006 23740 - BOB RIDINGS INC
08080110 - Battery 133960 28,798 Miles 2006084 WARRANTY REPAIR
Old Jun 22, 2007 | 07:43 PM
clueso21's Avatar
I had the same problem 04 pacifica. The sending unit in the fuel tank is bad is bad . I hada 100,000 mile warranty so for 50.00 I got it fixed.
It will gradually get worse until it no longer gives you a read out.
Old Jan 3, 2009 | 02:14 PM
JAB2208's Avatar
I realize this is an old post. But did a search and found this thread. My wife has an 04 pacifica with this fuel pump problem as well as a battery/starting issue (and a couple of other issues with it). Is it possible to check the vin on this and see if anything has been done? The vin is 4R182180.
Thanks in advance,
Jeff
Old Jan 4, 2009 | 08:30 AM
does not apply to your pac all recalls have been done.
Old May 1, 2011 | 06:04 AM
Ms.D's Avatar
Default Problems with 04 Pacifica; 3rd own 52,000 miles
I think theres something wrong with my whole dash board first off but my gas gauge doesnt work. & there was no oil in my car & the light never came on which is having me to think theres something wrong with my dashboard. If i give u my vin# could you tell me if i have any recalls? Thanks R631369, not sure if u need all #s, let me know & ill resend it.
Old May 1, 2011 | 06:07 AM
Ms.D's Avatar
Theres a 4 in front of the R.
Old Nov 12, 2013 | 08:36 AM
sivitec's Avatar
Hi,
Can you please check if my PCM would benefit if I ask the dealer to upgrade it? I'm having problems with my fuel gauge and they said that they will only flash if their computer connected to Chrysler would indicate that it would need reflashing.
VIN #6R887854
2006 Chrysler Pacifica AWD
96BTC
Sep 27, 2010 10:29 PM
Seano78
Jun 26, 2010 06:36 AM
lkwhalen68
Jun 19, 2007 09:58 AM
kb
Mar 22, 2007 10:44 PM
Sofargone
Aug 16, 2005 09:14 PM
