problems after refueling
Old Jan 10, 2009 | 11:39 AM
05pacifica's Avatar
Default problems after refueling
i have an 05 pacifica and when i fill it up and take the nozzle out it makes a gurgling sound. after that its start to act up by surging and stalling. after awhile it goes away and does do it until the next time i fill it up. any help would be appreciated.
Old Jan 22, 2009 | 08:29 PM
lookmannohans's Avatar
Default RE: problems after refueling
I have owned my Pacifica for almost 3 years now, and this just started happening to it. I just now started to notice the gurgling noise when filling up. It then runs very rough almost like a misfire or rough shift on the transmission type symptom. I have tried dry gas after the second time doing it, thinking water in tank. I have had it to the dealership and they said I needed an update, did that and still acts up. I thought maybe it was a pressure issue so I opened the gas cap and closed it and it didnt act up. It will only do it when I fill up more than 3/4 tank. I fi I fill up less than that it wont do it. It is only after I fill up and only last about 2-4 miles down the road until it goes away until next fill up. Please help!
Old Jan 23, 2009 | 08:47 AM
PacificaBus's Avatar
Have you had any problems with the fuel gauge not recognizing the correct amount of fuel in the tank? There has been a TSB in the past relating to the fuel pumps, gauge and stalling. Maybe ChryslerTech can chime in and give you more info.
Old Jan 29, 2009 | 11:51 AM
bradg's Avatar
I have an 05 Pacifica with te fuel gauge problem not recognizing the correct amount of fuel in the tank. At the same time of this problem, the tank won't take gas at the pump. You have to milk it really slowly. So far, 2000$ later, Chrysler has changed the two fuel sending units and the entire gas tank! Still no luck... They claim there is no TSB on the 05 for this problem.
Old Jan 29, 2009 | 06:51 PM
Ok so I got an answer from a chrysler tech on justanswer.com. I replaced the fuel vapor canister $80 bucks and the problem is solved. It literally took 10 minutes to change. He stated it was caused from topping off when filling up. Hope this helps.
Old Nov 20, 2014 | 08:43 PM
Ericbo101's Avatar
Default Anybody else fixed it that way too ?
Would change it too if I could get confirmation that it would solve the rough idle/stalling after full tank fueling
Thank you !
jsank
May 22, 2015 07:38 AM
Ericbo101
Nov 22, 2014 07:58 AM
TomC
23
Feb 22, 2013 06:14 PM
Edo300USA
Dec 6, 2012 06:30 PM
JE05T&C
Sep 2, 2011 09:41 AM
