Squeal/clunking noise when using A/C???
Old Aug 26, 2008 | 04:57 PM
Texas2008's Avatar
Default Squeal/clunking noise when using A/C???
I have a 2004 Pacifica with 30K miles and when I turn on the A/C a loud "clunk" noise happens when the compressor kicks in. After that initial noise, A/C works great, no noises or anything but when I turn the car off a loud squeal comes from under the hood. This clunk/squeal doesn't happen unless I'm running the A/C. The severity of these noises varies. Somedays it's quite loud, other days doesn't seem so bad.
My husband says it the bearings in the compressor going out. Has anyone experienced this before and in your best opinions, do you believe the air compressor is going out? Shouldn't it last much longer than 30K?
Thanks in advance!
Old Aug 26, 2008 | 07:24 PM
xfire04's Avatar
Default RE: Squeal/clunking noise when using A/C???
sounds like the clutch is going bad not the compressor
Old Aug 27, 2008 | 01:24 PM
Texas2008's Avatar
Thank you for replying. So, the A/C unit has a clutch and that is what you're referring to?
Old Aug 27, 2008 | 02:04 PM
xfire04's Avatar
the clutch is on the front of the compressor
Old Aug 27, 2008 | 09:42 PM
gbeach's Avatar
that clutch should not be going out at 30k. I have noticed weird things with my ac also, but after speaking with a chrysler engineer, some are just normal.
Old Aug 27, 2008 | 09:48 PM
gbeach's Avatar
the squeal could be the belt tensioner, bad idler pulley.should not be squealing. compressor kicking in is going to make some noise. if the clutch goes, it would most likely seize up causing the pulley to stop and very bad for the belt
Old Aug 27, 2008 | 09:55 PM
gbeach's Avatar
check little things first. how come only 30k on a 2004. the squeal when you turn off should be the problem, sounds belt related. Not saying it isn't the compressor, but when they go you know it.
Old Aug 28, 2008 | 05:29 PM
Texas2008's Avatar
It's actually a 2005, my typo - but still, I work from home so I rarely drive it. I will have the belt checked first. Thanks alot for the info!
GrahamLemon
May 13, 2011 05:16 PM
BeachBoy
Apr 6, 2009 08:05 AM
edevries
Dec 10, 2008 08:08 AM
romemtech
Oct 13, 2007 08:37 PM
97ysler
Feb 5, 2007 07:14 PM
