Strut has broken thru top of strut mount
Old Jun 17, 2014 | 12:27 AM
Freedom Hudson's Avatar
Default Strut has broken thru top of strut mount
So on my 2004 pacifica the passenger side strut has broken thru the top of the mount, the silver strut bar and nut are sticking out about 2 inches, it has even dented the hood, my question is when I remove the entire assembly am I going to have to compress the coil spring while it's still on the car ? From the reading I have done it says that the top nut is what holds the top mount to the coil spring.
Old Jun 17, 2014 | 01:27 AM
Yes it will still need to be compressed if u plan to uses the spring see if quick struts are avail
Old Jun 17, 2014 | 01:39 AM
I'm going to get a quick strut, I'm wondering if I can just remove the old assembly from the car the same as if the strut wasent broke thru the mount ?? Or will I need to compress the spring while it's still on the car ??
Old Jun 17, 2014 | 09:27 AM
all depends on how much clearance there is
Old Jun 21, 2014 | 01:18 AM
Well I got the strut off without compressing the spring, it came out just fine which is confusing because I read that the top nut is what holds the top of the mount to the compressed spring but obviously it's not.
Old Jun 24, 2014 | 06:10 PM
busboy4's Avatar
So is the top strut mount surface corroded? I have seen many town and country/Voyager etc where the mounts are toast. There is an after market repair kit for the vans that adds a new "cap" for the top strut attachment.
grifkac1
Aug 12, 2015 01:35 PM
bbatts
Apr 14, 2011 10:26 PM
2003sebring
Mar 23, 2011 01:19 PM
reksav
Jul 23, 2010 08:24 AM
nanu73bear
Sep 24, 2007 12:31 PM
