time belt alignment
Old Dec 19, 2017 | 11:31 AM
corvairbob's Avatar
Default time belt alignment
ok it replaced the timing belt and for the life of me i can't get the back cam to be perfect. i have the crank perfect and the front cam perfect but the back cam is like 1/4 tooth towards clockwise. i have the tensioner applied and i rotate the crank clockwise slowly and it comes back to the same place every time. so what is the consensus will after it is running and the belt stretches some align back to the marks? or will i have to retard it one tooth? i have been turning it clockwise and by turning that way it looks like if the belt stretches it will go back into alignment. does this sound about correct to you? do not want to put it all back if i need to do more? or is this about what i can expect? thanks
Old Dec 20, 2017 | 07:38 AM
install the tension-er then rotate the crank 2 full turns see where the marks align up if they are on the money when you install they will be after you rotate.
Old Dec 20, 2017 | 11:59 AM
corvairbob's Avatar
chrysler tech.
i installed the belt and the tensioner and did rotate the engine at least 4 times and the mark was still the same maybe a bit better. so i just assembled it and ran it and it is running fine. i think the belt will stretch and or wear in a bit and the mars will become aligned perfect. and if the tensioner does extend a bit that will make it better. thanks for the help.
now to work on the evap p0457 that did not go away after a gas cap replacement. it did go away after i took the battery terminal off but if i don't test for it then it may come back. it is not the links on the right side fuel pump. looked at thma and they are fine. but that is another post.
Karel
Sep 23, 2017 08:04 AM
latreto
18
Feb 25, 2017 10:11 AM
fjinnes
47
Jan 12, 2015 04:02 AM
goggs
Feb 22, 2013 03:54 PM
redpac
Aug 8, 2007 07:12 PM
