Timing Belt Replacement Error
Old Sep 22, 2011 | 10:13 PM
cowli4nia1's Avatar
Default Timing Belt Replacement Error
Had to replace water pump which required timing belt removal. Well, I did the job and car ran fine but "check engine" came on. Code read indicated "cylinder too Lean". Did the whole job over and now not firing. It must have been the valve shaft that turned on me several notches to the left and me assuming I can just turn back with ratchet.
No everything must be miss-aligned. What are my options? If any
Apr 3, 2012 02:50 AM
septicman
Mar 21, 2010 08:25 PM
Ruud
Jan 16, 2010 12:23 PM
gunga
Dec 28, 2006 12:46 AM
czama35
Jun 23, 2005 10:03 PM
