Transmission Service
Old Apr 7, 2009 | 02:13 PM
bizzob223's Avatar
Default Transmission Service
I have 72k miles on the car and I took it in for an oil change to find out that I have a shift solenoid leaking. Also I am due for a trans service. I want to chagne the fluid out and was wondering if anyone knows when they replace the shift solenoid with the have to drain the pan and replace the fluid? If not should I have a flush done on the trans ot just drop the pan and change the filter and oil in the pan? Its not shifting rough or anything, just thinking preventative maintenance.
Bob
Old Apr 7, 2009 | 10:27 PM
the sol pack is up top only loose a cup or so when changing it.
Drop the pan replace the filter.
Old Apr 8, 2009 | 10:26 AM
bizzob223's Avatar
OK thanks. Any idea how many quarts I will need to replace the fluid lost when I drop the pan? Also what brand of filter should I buy? And do they usually come with gaskets or use RTV?
Bob
Old Apr 8, 2009 | 10:55 PM
1 qt U use mopar so I have no opinion to other filters and use RTV
Old Apr 13, 2009 | 09:48 PM
indept's Avatar
Only 1 qt when you drop the pan & change the filter, sounds awful low?
LG300
Feb 19, 2015 07:10 AM
Edo300USA
Apr 14, 2012 01:25 PM
optimusprimer
Jan 6, 2012 10:54 AM
redfin123
Dec 2, 2008 08:38 AM
tshall
Jul 5, 2008 01:32 AM
