turn key on-off-on-off-on, throws code
Old Apr 17, 2008 | 08:47 PM
e49735's Avatar
Default turn key on-off-on-off-on, throws code
On my 05 pacifica, if I turn key on, off, on,off, on....it shows a diagnostic code....p0440...then hesitates and says p off, I think. I was reading about a post where a Town and Country owner was doing this to get codes and I did it on my pacifica and sure enough it threw up this code, but I don't know what it means.
anyone know about this?
Terry
Old Apr 17, 2008 | 08:55 PM
Default RE: turn key on-off-on-off-on, throws code
U have an evap leak in your system U will haft to inspect is for cracked lines in the rubber hoses.
Old Apr 17, 2008 | 09:19 PM
e49735's Avatar
http://www.engine-light-help.com/P00...ine-light.html
thanks, but I had it smoke tested and it turned up negative...the link above talks about the code and a relationship with "upstream oxygen sensor" not throwing an appropriate response, thus generating the code. It goes on to say that it could be faulty or crossed wiring or maybe just the sensor needs replaced....the car has 62K on it.
what do you think?
Terry
Old Apr 18, 2008 | 03:01 PM
U said 440 not 40 so which one is it and a smoke test will not alwase show up U are talking about a hole the size of a pin head as well.
Old Apr 18, 2008 | 07:14 PM
e49735's Avatar
Yes thanks again for your response....I think it was the 040 code, I just typed it wrong....I reset by disconnecting the battery and now it just says p done, when I do the key ...on/off, etc.
and the check engine light did not come on today,since the reset...I will keep my eye on it, and if it does reappear, will verify the code .
Assuming , that's the correct code, can it be an issue with the "upstream O2 sensor?"
thanks again,
Terry
Old Apr 19, 2008 | 05:25 PM
it wont because u erased the codes it will come back
Old Apr 20, 2008 | 08:13 PM
e49735's Avatar
Yes, it came back...and it is the evap p0440 code like I first reported....
so with a new gas cap, and a smoke test that doesn't show anything, and I desire to sell the car to someone who may be bothered by a check engine light, what do you suggest?
Purge solenoid, carbon canister, pin hole leak, etc. next steps?
thanks,
Terry
Old Apr 25, 2008 | 03:19 PM
farout's Avatar
Will the 07's do the same by the on off on method? How many on's and off's do we do? I know on my 05 liberty it did it, but for the life of me I can't remember how many times you do it. Thanks for the answer! (I hope)
farout
swittie
Nov 10, 2020 02:02 PM
Thumper
Jan 11, 2019 11:21 AM
Guy_laister
Mar 18, 2008 02:19 PM
murry
Dec 6, 2007 03:30 PM
t_bone_u13
Oct 29, 2007 10:20 PM
