Upper Rad hose pressure
Old May 21, 2019 | 12:24 PM
BiliTheAxe's Avatar
It should not be, one fan should only come on when the temperature hits a certain point, or in some cases when you turn the A/C on.
Old May 22, 2019 | 08:46 AM
djetelina's Avatar
Originally Posted by ChuckD82
I noticed that the fan on the driver side of the shroud does not kick on right away! Are they both supposed to kick on at the same time or are they independent from one another? I have to tap the fan for it to even kick on. Would that be part of the pressure build up issue?
The coolant fans on Pacifica's are wired in parallel. They should kick on/off and run at the same speed (they are variable speed), if they don't it is time to R&R. I have gone thru quite a few failed electric fan motors, never had any blow the radiator hose off..
Old May 22, 2019 | 08:04 PM
sivitec's Avatar
Sharing almost situation as pressure is building up on the coolant reservoir. I thought it was the thermostat. It turned out to be the driver side fan intermittently kicks in and/or if it kicks in, the RPM is not enough. It turned out that the fan motor is at fault already and I just changed it. Now cooling system is back to normal.
carltonwebb
Jul 22, 2021 07:51 PM
Daud
Jun 29, 2019 11:29 AM
bgyako
Jan 9, 2012 02:49 PM
g4j88
Feb 20, 2011 06:51 AM
