vehicle not in park????
Old Jan 9, 2014 | 07:30 PM
brianhaworth's Avatar
Default vehicle not in park????
Hi everyone, so I have an 04 Chrysler Pacifica AWD. This problem happened after sitting in a parking lot waiting on someone all of a sudden my battery light came on and then it said memory disabled, so I hurried and shut it off , would not start after that, no clicking nothing. Come to find out I found a ground cable going from the negative terminal to engine block had broke so there was no ground . Replaced that wire and starts beautifully now. But now every time I start my pacifica it pops up on the display that the memory is disabled. ? How do I reset this? And it also says vehivle not in park but it has never not started because of it like others I have read about.I had auto zone scan the check engine light and all that comes up is a emissions leak and a neutral park sensor or something so I bought the part but cant figure out where it goes. Is it in the shifter area? And how do I fix the memory disabled thing?
Old Jan 9, 2014 | 10:37 PM
exactly what part did u get? because the part switch is built into the transmission range sensor which is in the valve body assembly.
Old Jan 10, 2014 | 09:53 PM
It is the part that goes on the transmission, I believe it is called the neutral park sensor.
lockjaw36
Sep 26, 2017 01:38 PM
msd26129
Feb 19, 2015 05:08 PM
fe719
Feb 24, 2012 07:48 PM
Jun 12, 2005 03:25 PM
DSMLVR
Dec 16, 2004 09:17 AM
