Vibration when braking
Old Dec 22, 2009 | 10:30 PM
Hawwk11's Avatar
Default Vibration when braking
Hello guys.
Was wondering if any of you would possibly know what could be wrong? My wifes 05 pac. vibrates violently when braking, other than that it rides fine.
Thanks.
Old Dec 22, 2009 | 10:33 PM
warped rotors or abs wheel speed sensor
Old Dec 23, 2009 | 08:49 AM
desperado's Avatar
Mine does that once in a while (but I wouldn't say violently, more like a rapid wobble when I push the brakes a bit hard)
because it's intermittent, should I assume it's the ABS?
Old Dec 23, 2009 | 08:04 PM
Sierra8's Avatar
Default Warped brake rotors.
I just fixed this over the weekend. These are pretty heavy cars and the rotors can warp pretty quickly if you do a lot of city driving or towing (or drive your car in 100+ degrees in Texas weather while towing I took both rotors off and had them turned at a local auto parts store for 16 bucks. Bought some new brake pads and reassembled and the vibration is gone. If you can keep the brake rotors from warping I think the pads themselves would probably last til 100,000. Mine had 64,000 on it when I took the rotors off and the original pads looked to have a little over a 1/4 wear of the total pad.
You can usually feel warped rotors pulsating through the brake pedal if your vibration condition is the same.
Old Jan 10, 2010 | 09:54 PM
Hawwk11's Avatar
Thanks alot guys. You were right. It was the warped rotors, and that problem is solved. Now can you guys tell me while driving at 70+ mph the car vibrates. The steering wheel even shakes. I was thinking maybe it needs a balance but not sure.
Thanks.
Old Jan 11, 2010 | 05:58 PM
busboy4's Avatar
I have also found that the Caliper slides need regular maintenance - whenever I rotate tires anyway. It seems the Chrysler setup more so than others I have worked is susceptible to the caliper slides binding/loosing their lubrication leading to uneven pad wear and, I would think potential vibration. I use a high quality brake caliper grease and just pull them and lube them quickly while they are easy to get at.
Old Jun 3, 2010 | 09:28 AM
desperado's Avatar
Default Bump.
Question: If it's intermittent and happens at various speeds (sometimes not at all), is it more likely to be the speed sensor? if so, can it be adjusted? what's the procedure?
Thx
Old Jun 3, 2010 | 02:54 PM
its an electrical sensors on each wheel no adjustment
Old Jun 4, 2010 | 07:56 AM
desperado's Avatar
ok. so I was reading about warped rotors, and found this article which I thought was pretty interesting.
So this morning I did a little test with some "hard" breaking patterns from 35 mph, to see if I could clean/scrub the rotors. Vibration seems to have improved a bit. Probably shaved a bit of the pads off too.
However, this being a used car, I took a look at the rotors and it looks like a some point the brake pads must have been used all the way down, because it looks like there is (what I figure to be) a piston groove along 1/2 inch perimiter of the rotor.
KingJB
Jan 29, 2014 05:13 PM
ietk
Feb 21, 2010 07:35 AM
neoncrazy101
Sep 7, 2009 06:05 PM
edevries
Dec 10, 2008 08:08 AM
mhellam
Sep 3, 2008 11:53 PM
