Where is the internal fuse box for a 2004 Pacifica located?
Old Mar 8, 2007 | 02:17 PM
TazExprez's Avatar
Default Where is the internal fuse box for a 2004 Pacifica located?
Hi, I would like to know where the internal fuse box for a 2004 Pacifica is located. I only found the one under the hood. Thanks for any help.
Old Mar 8, 2007 | 06:32 PM
Default RE: Where is the internal fuse box for a 2004 Pacifica located?
thats because there is only the one under the hood. What are u looking for that u did not see in the fuse box under the hood?
Old Mar 31, 2007 | 01:20 PM
nvspacifica's Avatar
Do you know what fuse controls the Fog Lights? I can't seem to find it and my fogs aren't working. However, the foglight indicator does show up in the dash. Could it be a fuse or do you think the bulbs need to be changed?
Old Apr 1, 2007 | 02:18 PM
jamie1's Avatar
Checking the bulbs would be the first thing to check. The fog lamps are controlled be the BCM which sends a signal to the IPM[The fuse and relay block you see under the hood. ] The IPM could be the cause since both are out. A scan with a DRB scanner may yield a fault code stored.
Old Jul 20, 2013 | 12:49 PM
Tk Walton's Avatar
Headlights and park and taillight want come on windshield wiper want work
Old Jul 20, 2013 | 01:48 PM
start a new post will all your info in it
Old Aug 15, 2022 | 09:55 PM
ASKELLER's Avatar
Default 2005 chrysler pacifica
We have been working on this car for days. When we hit a pot hole, suddenly the electric panel went out /radio went out /windows stopped working, and then came back on. We drove home OK and parked it. starts up OK, but will not shift out of park, all of the following do not work;
power windows, lights, horn, power cigarette outlet, and will not shift out of park. alot of trouble lights all on including abs brakes, parking brake light, RPM meter going crazy, although it is running smooth but wont shift out of park.
we have checked the grounds from the PCM with ground test light, they all appear grounded, cleaned them all off.
car computer will not send codes to code tester.
not sure what to do next. running out of ideas. Please advise..
Old Aug 15, 2022 | 09:58 PM
ASKELLER's Avatar
radio also not working/ fan on a/c blower not working, nothing on dash comes on.
Old Aug 16, 2022 | 07:30 PM
check the fuses for power on both sides when the key on
Old Dec 7, 2023 | 10:27 AM
Helpme2019's Avatar
Default 2004 Pacifica fuel glove box light which fuse shuts it off
I have a 2004 Chrysler Pacifica glove box light fuse I don't know which one it is which fuse shuts off the light
alexyoung59
Oct 7, 2011 04:59 PM
bdmpit
Sep 24, 2011 10:03 AM
gujju
Oct 1, 2010 01:15 PM
wv53
19
Apr 13, 2009 05:35 PM
protocol_droid
Jan 29, 2007 03:06 PM
