Wiring Diagram?
Old Apr 11, 2007 | 12:30 PM
nvspacifica's Avatar
Default Wiring Diagram?
I'm installing headrest monitors and I need a 12v source. Can anyone tell me what color and where I would find the wire to tap into? Steering column maybe? Is there a constant and a switched?
Thanks for all the help guys.
Old Apr 11, 2007 | 01:24 PM
Default RE: Wiring Diagram?
which do u need key on or all the time??
Old Apr 11, 2007 | 05:25 PM
Both would probably help.
Old Apr 11, 2007 | 05:36 PM
need year and engine size or last 8 of vin if u want correct wire color
Old Apr 14, 2007 | 02:13 AM
2004 3.5 v6
Old Apr 17, 2007 | 10:04 PM
CAV CIRCUIT FUNCTION 1 G900 22OR/VT IGNITION SWITCH SENSE RETURN 2 G20 22VT/BR IGNITION SWITCH SENSE 3 F20 20PK/GY IGNITION SWITCH OUTPUT (RUN-START) 4 T751 20YL IGNITION SWITCH OUTPUT (START) 5 A106 20LB/RD FUSED B(+)
The LB/RD is hot all the time and the PK/GY will be hot with the key on
engwrc
Jan 12, 2008 08:46 PM
dachozn1
May 8, 2007 09:03 PM
WifesVan
Jan 20, 2007 01:11 AM
trueburton
May 18, 2006 09:08 PM
