01 pt cruiser windows
Old Feb 29, 2024 | 06:54 AM
esty's Avatar
Default 01 pt cruiser windows
rear power windows are not locked and don't work at all, ever.... fronts recently started working intermittently...there's no fuse for windows what should i check
Old Feb 29, 2024 | 10:01 AM
esty's Avatar
i just discovered that giggling the key in the ignition with car running gets the front windows to work but no back window operation
Old Feb 29, 2024 | 05:25 PM
check for power and ground at the window motors to start
Old Mar 1, 2024 | 06:47 PM
esty's Avatar
when windows don't work no power or ground at switch...giggle key, power's at switch
what controls power to windows, there is no fuse...it appears it gets power from ignition switch and i don't have a clue what to check
Old Mar 2, 2024 | 09:44 AM
ggoose's Avatar
If jiggling the key gets power to the windows it may be the ignition switch (not the key cylinder). There is a single power feed to the ignition switch. Rotating the key will send the power to the various systems. A number of examples, the ACC position will power the radio and wipers, the RUN position will power the radio windows and fuel pump, the START position will power the fuel pump and starter.
The switch can be had for about $25 so it is your call to fire the parts cannon (search for pt cruiser ignition switch). This link shows how to replace the switch.
Old Mar 3, 2024 | 03:04 PM
the power to the switch goes threw a circuit breaker in the fuse box on driver side. that power to there comes from the ign switch that same circuit from the ign switch also controls the blower motor so if the windows and blower motor not working at the same time then likely the ign switch if not look at the fuse box area.
PTcruiser
Oct 1, 2023 12:47 PM
PTcruiser
Oct 1, 2023 05:36 AM
Timo13
Sep 12, 2020 04:35 PM
coolvanilla05
Sep 25, 2007 05:52 AM
QuickSilver05
Apr 3, 2006 03:50 PM
